TwinTurbo.NET: Nissan 300ZX forum - Z won't turn over!!!!
Subject Z won't turn over!!!!
Posted by TTZ2NV(TX) on February 05, 2010 at 2:43 PM
  This message has been viewed 287 times.
Message I was wondering if anybody has ever encountered this particular
problem, My mind is boggled. When the key is turned everything lights
up on the dashboard, radio, fuel pump all activates. When it is turned to
the start position I get nothing. I have a clicking noise coming from the
blue relay closest to the firewall on the fuse panel by the drivers feet
which will click regardless if the clutch is depressed or not. At this point
I've:
Removed and tested started
Replaced starter relay
Replaced clicking realy
Researched schematics
Checked fuses and related relays
Jumped neutral position switch at clutch pedal
I was hoping that somebody would know what this problem was, or
would know what the relay was for on the fuse panel by the drivers feet.
Its the Blue relay on the back of the fuse panel by the drivers feet, it is
the blue relay that is closest to the firewall. Thanks in advance for your
help and have a great super bowl weekend.
