TwinTurbo.NET: Nissan 300ZX forum - ECU says code 55, has multiple times..
arkansasturbo
on February 05, 2010 at 8:15 AM
Have you run ECU diagnostics? 2nd thing I would do is
posted by Audioquest
on February 05, 2010 at 07:46 AM
Boost leak test passes fine, multiple times also. I'm
pretty positive that all vacuum lines are hooked up
properly as well
Still having post plenum pull issues...
arkansasturbo
20:44:56 02/04/10
Audioquest
07:46:23 02/05/10
ECU says code 55, has multiple times.. -
arkansasturbo
08:15:24 02/05/10
Re: Still having post plenum pull issues...
paintballkustoms
09:38:30 02/05/10
paintballkustoms
09:48:51 02/05/10
i only understood that cause i have a 15 yr old sister...
arkansasturbo
10:41:01 02/05/10
Re: i only understood that cause i have a 15 yr old sister...
paintballkustoms
11:01:01 02/05/10
no that makes sense
arkansasturbo
11:30:41 02/05/10
Re: no that makes sense
paintballkustoms
12:33:48 02/05/10
The amount of fuel deliverd depends on the size of
xteam300tt
11:34:51 02/05/10
Re: The amount of fuel deliverd depends on the size of
paintballkustoms
12:31:26 02/05/10
paintballkustoms
11:11:49 02/05/10
yeah i saw that too
arkansasturbo
11:34:16 02/05/10
There's a 94 tt FPCU in the classified $100 (n/m)
xteam300tt
11:55:10 02/05/10
Re: There's a 94 tt FPCU in the classified $100
paintballkustoms
12:24:00 02/05/10
dont jump on that new fpcu just yet
arkansasturbo
12:48:23 02/05/10
Re: dont jump on that new fpcu just yet
paintballkustoms
14:25:16 02/05/10
yours behaves perfect with the maf unplugged? (n/m)
arkansasturbo
15:03:22 02/05/10
Re: Re: dont jump on that new fpcu just yet
paintballkustoms
01:25:33 02/10/10
You can bypass the FPCU and hardwire the pump to test >>>
my91z
16:59:16 02/05/10
