TwinTurbo.NET: Nissan 300ZX forum - Re: Re: Re: Clunk on take off. Clutch, transmission, differential or
Subject Re: Re: Re: Clunk on take off. Clutch, transmission, differential or
Posted by Gho32 on February 04, 2010 at 7:35 AM
  This message has been viewed 149 times.
In Reply To Re: Re: Clunk on take off. Clutch, transmission, differential or posted by Gho32 on February 02, 2010 at 10:50 AM
Message I guess I should elaborate a little more, the OEM bushings up front are pretty much solid with an insulator. The ES I received from Coz were a softer compound up front than the others received in the same kit.
Due to the extra movement, the diff was knocking the lower bracket up front.. If you remove the bracket you should be able to see if or where it's contacting.. If that's the cause, another option to OEM or grinding 'may' be to space out the bracket so it sits a bit lower.
