TwinTurbo.NET: Nissan 300ZX forum - Re: Just replaced oil pump/t-belt/tensioner now i have a knock
Subject Re: Just replaced oil pump/t-belt/tensioner now i have a knock
Posted by penguintits on February 03, 2010 at 1:20 AM
  This message has been viewed 80 times.
In Reply To Just replaced oil pump/t-belt/tensioner now i have a knock posted by penguintits on February 01, 2010 at 01:15 AM
Message the knock started as soon as the engine turned over, the oil pressure moved off of zero in about 5 seconds and steadily inclined to 60psi, but the second time i started it it would not go pass 40 psi at 3000rpm.
I bought the oil pump new from nissan OEM. I have yet to put a manual gauge on the sending unit, but i did do that before the swap and my gauge in the car was correct then so it still should be correct now, also i put a new EFI harness while the motor was out. however what did just pop in my memory was a o-ring the went between the oil pump and the pick-up tube that was missing, i don't think that would effect the oil pressure seeing as the groove for the o-ring to sit is inside the tubing not between where both flanges meet.
