TwinTurbo.NET: Nissan 300ZX forum - Using TT ECU with NA controller
Subject Using TT ECU with NA controller
Posted by njz on February 02, 2010 at 2:01 AM
  This message has been viewed 154 times.
Message In reviewing fuel pump controller circuit, it seems to be identical with the exception for pin 35 at the ECU which connects FP controller. I believe since the NA controller is not setup for the 6 volt speed the controller will not receive signal and therefore continue to run at the 8 and 12 Volts NA set up, so it should be okay to use a TT ECU with NA FP controller. If anyone has information to the contrary please let me know. In addition if anyone has pictures of NA & TT controller circuit board please post them.
