TwinTurbo.NET: Nissan 300ZX forum - If you can drill and tap a hole, and in aluminum >>
Subject If you can drill and tap a hole, and in aluminum >>
Posted by Gordo 93TT Daytona on February 01, 2010 at 7:19 PM
  This message has been viewed 269 times.
In Reply To Re: "it really isn't that hard." Thats music to my ears... posted by BeaZty on January 30, 2010 at 11:03 AM
Message that is a fairly easy process; then you can install the helicoils. A larger hole is drilled to remove old threads, and then a wider diameter, same pitch tap is run through. The helicoil is screwed down, seated, and then the "driver tab" is snapped off. I think your biggest concern will be keeping metal chips from falling down into the plenum.
_________________________________________________
