TwinTurbo.NET: Nissan 300ZX forum - HeliCoil kit measurements. For 12mm acorn nut stud.
BeaZty
on January 31, 2010 at 10:38 PM
stripped threads inside bolt hole of plenum to balance tube.
posted by BeaZty
on January 27, 2010 at 03:55 PM
HeliCoil Kit number 5546-8
HeliCoil tap size M8x1.25
drill bit size 21/64
BeaZty
15:55:57 01/27/10
Passenger side should be using a nut, not a bolt.
Woody75 (Denver)
16:58:24 01/27/10
here is a pic to clarify.
BeaZty
18:00:22 01/27/10
Should be a stud and acorn nut there, not a bolt. (n/m)
Fast300
22:20:24 01/27/10
^^^ listen to them it is a nut on a STUD. NOT a BOLT (n/m)
5280Z_nightstalker
13:01:53 01/29/10
lol, ok you win. the acorn nut. (n/m)
BeaZty
13:43:41 01/29/10
Buy the heli coil kit for the bolt size. ie 8mm, 10mm etc
Zjustignoreme
18:35:40 01/27/10
thanks, I will buy the 12mm helicoil kit for the acorn bolt.
BeaZty
09:50:57 01/29/10
12mm is too big
Fast300
18:02:30 01/29/10
Re: stripped threads inside bolt hole of plenum to balance tube.
Marty1Mc
06:39:12 01/30/10
Thanks Marty, your tips are greatly appreciated.
BeaZty
08:00:43 01/30/10
Re: Thanks Marty, your tips are greatly appreciated.
Marty1Mc
08:21:47 01/30/10
Re: "it really isn't that hard." Thats music to my ears...
BeaZty
11:03:54 01/30/10
If you can drill and tap a hole, and in aluminum >>
Gordo 93TT Daytona
19:19:47 02/01/10
HeliCoil kit measurements. For 12mm acorn nut stud. -
BeaZty
22:38:18 01/31/10
