TwinTurbo.NET: Nissan 300ZX forum - Inspect the connectors for green corrosion and clean>>
Subject Inspect the connectors for green corrosion and clean>>
Posted by ZUL8TR on January 31, 2010 at 4:07 PM
  This message has been viewed 80 times.
In Reply To Re: Use a digital voltmeter - on resistance setting and verify posted by ZaddicteD on January 30, 2010 at 03:03 PM
Message also look at the connector prongs in the injector and clean them as well. Use chemical clean. Fill connector with dielectric grease and replug. If connectors cannot be cleaned you probably need to replace them. Sometimes the full corrosion is not known until the wires leading into the connectors are inspected because the corrosion will travel up the wire - it happened to me.
ZUL8TR in Orlando,FL
