TwinTurbo.NET: Nissan 300ZX forum - How is the oil pressure related to the tune? If the >>
Subject How is the oil pressure related to the tune? If the >>
Posted by ZUL8TR on January 31, 2010 at 4:01 PM
  This message has been viewed 158 times.
In Reply To Universal Tune Advice posted by krob19111 on January 31, 2010 at 02:35 PM
Message engine failed due to low oil pressure as you say then something in the oil pressure system failed like the oil pump, rotated babbit bearings on crank or rods, major external leak, blockage in passages or .....? Why didn't you stop when the oil pressure dropped and check out the reason? Maybe the timing belt failed?
What was the max speed and for how long on the trip home?
I hope you got a great deal on the car so with the replaced engine it doesn't dump you too far down.
ZUL8TR in Orlando,FL
