TwinTurbo.NET: Nissan 300ZX forum - Dont run the engine anymore !
Subject Dont run the engine anymore !
Posted by xteam300tt on January 30, 2010 at 7:06 PM
  This message has been viewed 97 times.
In Reply To Intake Camshaft posted by TRdave on January 30, 2010 at 06:37 PM
Message if the cam was not turning you have valves open . odds are it was turning or your engine would not start and the pistons would have slammed the valves , this doesnt mean the sprocket didnt walk alittle , it had to of since it sheered the pin off , you may have gotten real lucky . dont know if you can press a new pin in or not , thats a question for someone else . your loud intake and idle problem could be from the timing being off due to that sprocket or you have a vacumm leak at the intake gasket . either way it'll probably all need to come back apart if you cant drill and press a new pin and reset the timing belt.
