TwinTurbo.NET: Nissan 300ZX forum - Pull the coil pack connectors one at a time...
Subject Pull the coil pack connectors one at a time...
Posted by DVDBURN (MD) on January 30, 2010 at 11:16 AM
  This message has been viewed 126 times.
In Reply To How do i check if one of coil packs is bad posted by skyladyzx on January 30, 2010 at 11:00 AM
Message with the engine running. You should notice a difference in how the engine runs. If no change then troubleshoot why your not getting ignition at that cylinder. It's usually something other than the coil packs because they hardly ever go bad. The most likely cause is bad connections to the CAS, PTU or injector connectors. Or a bad CAS or PTU. If you have ever disconnected the ECU make sure the connector going to it is well seated too.
www.mytwinturbo.com
Watch an ECZA meet caravan!
Download my Nissan 300ZX Vin/Model Lookup
