TwinTurbo.NET: Nissan 300ZX forum - What's this EFI plug?
Subject What's this EFI plug?
Posted by arkansasturbo on January 30, 2010 at 10:41 AM
  This message has been viewed 129 times.
Message I bought a 95 TT 5spd harness to replace the old horrible one in my 90 TT 5spd. However, on this harness there is a plug that I cannot seem to find a home for. If you pull out the nose panel, you'll see the MAF and its harness connector. About 6-10 inches towards the rest of the harness, on the same "branch" the MAF connector is on, there is the connector in question. It looks almost identical to the CAS connector of later year cars, but it is narrower. It's gray with yellow on the inside, and does NOT fit the CAS so I know it isn't that.
You will not see this connector if you do not lift the nose panel off. It is forward of the radiator core support, and as mentioned before on the same "branch" as the MAF connector. Any ideas?
