TwinTurbo.NET: Nissan 300ZX forum - A/T woes
Subject A/T woes
Posted by tinner on January 27, 2010 at 3:32 PM
  This message has been viewed 113 times.
Message 91 stock engine rebuild, new main harness, rebuilt stock turbos. All this bolted to the Automatic Transmission. The car shifts fine when cold or warm. Without O/D it runs 50MPH at 2500 RPMs. If I kick it down to passing gear, it shifts down and will not shift back into third. It will run 50MPH's at 4800 RPM's. Overdrive switch will not work once I kick it into passing gear. Letting the car cool down it works fine until passing gear is engaged. I have adjusted the TBS to 4.v volts. Did a transmission service and can not do an auto diagnostics due to the fact that It has no lights in the dash. So now I still looking for a Consult I.
Thanks
Al
