TwinTurbo.NET: Nissan 300ZX forum - I had this issue.
Subject I had this issue.
Posted by Woody75 (Denver) on January 27, 2010 at 2:50 PM
  This message has been viewed 92 times.
In Reply To Trunk posted by MyDreamZ on January 27, 2010 at 11:30 AM
Message My NA only came with the valet key which won't open the hatch. And when I used the lever it wouldn't "pop" and unlock/open. If I had someone lift on it the lever would work. I fixed by adjusting the latch in the hatch. Pretty easy. Remove the lower center hatch plastic part so you can see the latch. Loosen the bolts and see if you can lower it/push it down at all. Might not move much which is fine, mine didn't either but it was just enough. Tighten it down and try the handle again to see if it will work. You should hear it pop when you pull the handle
JackB nimble JackB quick JackB can suck my dick =P - james-lee 11/02/01
Arrogance is the #1 weapon against Supra Owners - MikeH 08/06/02
Dallas with a Z: I like the bulge dude 05/02/03
Bezbefootball: Does dick have anything for me? 10/21/03
