TwinTurbo.NET: Nissan 300ZX forum - Yes, they'll work fine
Subject Yes, they'll work fine
Posted by Broke_as_**** on January 27, 2010 at 8:36 AM
  This message has been viewed 101 times.
In Reply To Re: The turbine housing is slightly different posted by starscream714 on January 27, 2010 at 01:56 AM
Message You'd probably be hard pressed to notice any difference without driving an identically setup car with manual turbos back to back. All of the piping and bolt holes are the same, it's just the taper (A/R ratio) of the turbine housing that's different. If you really wanted to you could try picking up a blown set of manual turbos and swap the exhaust housings so you have the .63 turbine housing, though as mentioned, you probably wouldn't be able to notice the difference anyway.
