TwinTurbo.NET: Nissan 300ZX forum - The turbine housing is slightly different
Subject The turbine housing is slightly different
Posted by Broke_as_**** on January 27, 2010 at 12:48 AM
In Reply To Re: Yes. Pic Here. posted by starscream714 on January 26, 2010 at 11:44 PM
Message You really couldn't tell just by looking at it. However if you look just inside the turbine inlet the A/R ratio should be stamped into the side towards the outlet flange. Or it should be on the outside, just below the inlet flange on the side facing the center housing. .63 is manual, .54 is auto.
