TwinTurbo.NET: Nissan 300ZX forum - Any tire wear?
Any tire wear?
Zjustignoreme
on January 26, 2010 at 6:38 PM
Front Wheel Shimmy due to 350z rotor upgrade?
posted by enthuZiast
on January 26, 2010 at 01:28 PM
An alignment problem can cause a shimmy as the tires try to pull in different directions. Once the tires get hot and flex more the problem can seem to go away. When is the last time you had an alignment?
enthuZiast
13:28:44 01/26/10
I like #1 as a probable. Did you put new pads on when you >>
ZUL8TR
14:52:21 01/26/10
Re: I like #1 as a probable. Did you put new pads on when you >>
enthuZiast
17:31:05 01/26/10
I don't think it's either one. The first sign of rotor warp
zellamay
16:37:09 01/26/10
Re: I don't think it's either one. The first sign of rotor warp
enthuZiast
17:27:10 01/26/10
Any tire wear? -
Zjustignoreme
18:38:43 01/26/10
I would check for play in the kingpin and wheel bearings
canyoncarver
19:22:15 01/26/10
What kind of tires are you running?
Spddracer
21:51:20 01/26/10
2nd. very probable especially that high performance tires>>
ZUL8TR
08:13:03 01/27/10
