TwinTurbo.NET: Nissan 300ZX forum - Have you even looked at the brake caliper making noise?
Subject Have you even looked at the brake caliper making noise?
Posted by Zjustignoreme on January 26, 2010 at 6:32 PM
  This message has been viewed 81 times.
In Reply To Noise concerns posted by 91ttzx on January 26, 2010 at 05:40 PM
Message Is all the hardware in place and installed properly? Sounds like the top leaf spring may not be on properly. Check your pad install.
Lifters tick, do a search. knock can be anything from a rod to a bearing in the timing belt. You need to provide more info. A stethiscope can pinpoint sounds. A long screwdriver can be used also like a stethascope. The sound needs to be isolated first. I hope this little bit can help you.
