TwinTurbo.NET: Nissan 300ZX forum - Re: rotating the motor by hand, to set the belt tension, pushes
Subject Re: rotating the motor by hand, to set the belt tension, pushes
Posted by TRdave on January 23, 2010 at 7:38 PM
  This message has been viewed 117 times.
In Reply To rotating the motor by hand, to set the belt tension, pushes posted by fanta-z on January 23, 2010 at 12:02 PM
Message It really isn't a tapping sound. It is just a loud intake grunt type noise. I don't remember it being so loud before. I also had the plenum off thinking my oil leak might have been a valve cover gasket so maybe a vacuum line is messed up. Does anyone have a good vacuum line diagram?
:oil out of the lifters. After I did my timing belt there was lifter tick for a few minutes. This doesn't explain stalling but just know a temporary tapping sound may be normal.
