TwinTurbo.NET: Nissan 300ZX forum - Re: Timing question, runs and sounds rough
xteam300tt
on January 22, 2010 at 12:50 PM
posted by TRdave
on January 22, 2010 at 12:23 PM
mine did that and it ended up being a vacuum leak , found it by doing a boost leak test . what is your timing set at ?
TRdave
12:23:48 01/22/10
Re: Timing question, runs and sounds rough -
xteam300tt
12:50:07 01/22/10
Re: Re: Timing question, runs and sounds rough
TRdave
15:06:05 01/22/10
Timing belt marks are only the beginning point.
de944
15:28:18 01/22/10
CAS
ZTurboFan
16:29:13 01/22/10
Re: CAS
TRdave
17:32:27 01/22/10
Looks OK
ZTurboFan
21:27:55 01/22/10
Re: Looks OK
TRdave
23:18:03 01/22/10
Unsure. Defer to NA person.
ZTurboFan
23:53:34 01/22/10
rotating the motor by hand, to set the belt tension, pushes
fanta-z
12:02:58 01/23/10
Re: rotating the motor by hand, to set the belt tension, pushes
TRdave
19:38:29 01/23/10
With timing belts always count the teeth between the>>
ZUL8TR
08:59:44 01/25/10
