TwinTurbo.NET: Nissan 300ZX forum - Good to know. But still not the optimal technique.
Ashman2k2
on January 21, 2010 at 7:15 PM
Energy Suspension 913104-G: $3.99 (n/m)
posted by Jehannum
on January 21, 2010 at 07:10 PM
As I said above, a good sold hit to the knuckle will pop it out
with a heavy hammer.
How do you remove the outer tierod from the spindle?
collegeboy
15:08:01 01/21/10
I had no luck with that method either.
opus300zx
15:18:52 01/21/10
2nd (n/m)
Turnerscasa (Dallas)
15:55:21 01/21/10
Are you replacing the outer tie rod end? If so, you can
300MPH
15:23:07 01/21/10
I had to use a tie rod puller on the rear outer tie rods.
Wright (Ca)
15:33:40 01/21/10
PB Blaster and a hammer worked perfectly!
collegeboy
16:05:06 01/21/10
Lets see some pics (n/m)
MannyB
16:35:20 01/21/10
Sorry dude. I didn't really take pictures.
collegeboy
08:33:15 01/22/10
Re: PB Blaster and a hammer worked perfectly!
toykoz32
16:57:35 01/21/10
You have to hammer the body of the spindle to vibrate
Ashman2k2
17:35:18 01/21/10
When I did mine.....
zx299
17:41:01 01/21/10
yes i used a puller tool as well
gt300zxtt
20:47:05 01/21/10
Pickle Fork.
Jehannum
18:37:49 01/21/10
Negative. Will ruin boot. (n/m)
Ashman2k2
19:02:14 01/21/10
2nd that big time. just experienced it (n/m)
KasbeKZ
19:05:49 01/21/10
Jehannum
19:10:24 01/21/10
Good to know. But still not the optimal technique. -
Ashman2k2
19:15:30 01/21/10
The correct answer is a Tie Rod/Pitman Arm Puller
aliaZ
20:47:54 01/21/10
Same one I used, worked perfectly. (n/m)
Wright (Ca)
21:10:44 01/21/10
i've been meaning to pick one of these up. (n/m)
Halo Z
22:14:12 01/21/10
I use this tool. I think Sears sells it as well.
Woody75 (Denver)
08:18:47 01/22/10
thanks for the link
aliaZ
11:34:22 01/22/10
I think this is the tool listed/shown in the manual as well. (n/m)
Woody75 (Denver)
10:41:50 01/26/10
