TwinTurbo.NET: Nissan 300ZX forum - rich idle problem, need some direction
Subject rich idle problem, need some direction
Posted by de944 on January 19, 2010 at 6:21 PM
Message I just had my emissions test done and my co and hc at idel were way too high. At 2500rpm, they were fine. The car passed last year without any problems. I have made no significant changes to her in the past year. Can anyone give me some direction to look. I did a search on rich idle (and variations of that) and found nothing conclusive. The emissions specs are below. I am guessing that I have a possible lower injector o ring leak. I have not found a way to test for that. Any clues why it's rich at idle but fine at 2500 rpm. I did all of the basics power balance test, boost leak test, vacuum leak test, check timing, tested the following per the FSM; MAF, Engine temp sensor, TPS. BTW, the idle is smooth and even. Fuel economy has dropped in the past few weeks from 18 mpg in town, to 17 mpg in town.
As a side note, I do have low compression on cylinder 1 which would account for some of the hc being high.
2009 2500rpm
co .88
hc 113
2009 idle
co 1.2
hc 128
2010 2500rpm
co .66
hc 116
2010 idle
co 3.21
hc 339
