TwinTurbo.NET: Nissan 300ZX forum - Some points
Subject Some points
Posted by lazer(NV) on January 18, 2010 at 4:36 PM
  This message has been viewed 912 times.
In Reply To Causes of injector failure. posted by DVDBURN (MD) on January 18, 2010 at 06:14 AM
Message First, the entire injector is assembled via a 'drop in' method. Every part is dropped in from the top of the injector body. In my cutaway injector this can clearly be seen. The 'spring guide' is actually just a copper plug. Out of the eight injectors I had fail not a single one leaked out this seal.
Second, the pintle assembly picture you have isn't very good. Here's a better one:
It does not use a rivet to hold the cap and body of the pintle together. I believe them to be a press fit or possibly bonded before final machining of the cap.
Third, there are a total of 4 o-rings inside the injector body.
"The 300ZX Turbo is a dance; it's a song; it's rolling, roaring automotive art. There is no color that doesn't suit it. There is no mood-lifting chemical substance it can't replace." - Automobile Magazine
