TwinTurbo.NET: Nissan 300ZX forum - The circuit still must be completed for the 12 volt
Subject The circuit still must be completed for the 12 volt
Posted by not4resaleZ on January 18, 2010 at 3:45 PM
  This message has been viewed 839 times.
In Reply To Perhaps I am missing something but I feel the problem isn't posted by alpha_omega16 on January 18, 2010 at 02:54 PM
Message issue to make any difference. Current must flow. The water could short across the connections, but it still needs a complete path to the negative ground. The negative wire of the connections is not a path unless the ecu closes the circuit by trying to fire the injector. When the ecu closes the circuit, the moisture could create another current path, directly between connections and this could cause corrosion. This would only occur when the ecu closes the circuit, and the re-wire would not stop it.
