TwinTurbo.NET: Nissan 300ZX forum - NA and TT ECU's are specific to the engine.
Subject NA and TT ECU's are specific to the engine.
Posted by kkrofft (OH) on January 18, 2010 at 10:27 AM
  This message has been viewed 143 times.
In Reply To engine swap posted by zapco on January 17, 2010 at 10:17 PM
Message The most important issue is that the injector sizes are different and so you can't swap just the ECU. You have to match the ECU to the injectors used. You could swap TT injectors into an NA and still use the TT ECU but the TT maps are tailored for the NA engine which has much higher compression so it won't perform well. Fix the turbos. It will be easier in the long run and FAR more enjoyable. It would also preserve the resale value.
KKROFFT
Now occurs everywhere, simultaneously. But it doesn't have to be experienced the moment it happens.
Every now that ever was is still exactly when it was, when it was now.
Then, in terms of perception, is nothing more than all the nows that are no longer now.
Thus, the difference between now and then is when.
   --The Waystoppers Users' Manual
