TwinTurbo.NET: Nissan 300ZX forum - I think the only difference is that the TT lower arm
Subject I think the only difference is that the TT lower arm
Posted by just4kinks on January 16, 2010 at 10:19 AM
  This message has been viewed 162 times.
In Reply To Front Suspension: TT vs. NA posted by 300zxer on January 16, 2010 at 02:21 AM
Message has a bracket to bolt the t-rod air deflector.
The lower arm has a ball joint and a bushing. The upper arms have 4 bushings each. The upper arms are only worth buying if the bushings are good -- the bushings are too expensive to be worth replacing. For the lower arm, you can always install an ES bushing and a Moog ball joint.
