TwinTurbo.NET: Nissan 300ZX forum - ConZult and Adapter Issue *solved
Subject ConZult and Adapter Issue *solved
Posted by ZPUHost on January 13, 2010 at 9:41 PM
  This message has been viewed 582 times.
Message I recently purchased a consult adapter w/ the free ConZult software. I had issues connecting to the computer running windows 7 and a USB to rs232 serial connection.
After numerous attempts / connection errors / ecu diagnostics and checking fuses and everything.
My battery was low.
My consult would not connect/detect or perform any functions with the car in the on position only while the car was running. (the reason is the low voltage i assume)
I tested the com ports with a serial mouse and verified that the USB to RS-232 was working properly so just a word to the wise in Z land that the consult is self powered and will not initialize unless you've got a strong battery.
For those troubleshooting these issues also, in The Nissan Datascan i was able to detect the ports the ECU was on but no part number would show up.
Mine battery was around 10V+/-. ConZult would not operate until i got 14V+/-.
  • ConZult and Adapter Issue *solved - ZPUHost 21:41:17 01/13/10
