TwinTurbo.NET: Nissan 300ZX forum - Can use some advice on what happened with the Z tonnight
Subject Can use some advice on what happened with the Z tonnight
Posted by steven fl on January 13, 2010 at 9:15 PM
  This message has been viewed 103 times.
Message I have oil leaks front of engine, valve covers and rear main. Been for a while. Today smoke coming out from hood. Figured maybe oil dripping on manifold?, o.k. Then noticed on the temp pod,the fan pic and numbers in the little window would go on and off, sometimes fading off. Then later(at dark) went to turn on heads lights, there were none, flashed on high beams and they came on then quickly went off like a fuse popped and they didnt work again. Opened hood smelled like burning rubber, Im assuming maybe,, the oil which it looked like was dripping on one of the lower front belts-maybe causing to slip -hence the burn rubber smell? So far I checked fuse for head lights underhood and they are good. Not sure if the headlight-low/highs have anything to do with the temp window. Can the problem be in the head light switch inside pod?? Or even in the temp pod?? Thanks for any advice out there,Steve
