TwinTurbo.NET: Nissan 300ZX forum - Re: Thermostat Housing
Subject Re: Thermostat Housing
Posted by Da Flash on January 13, 2010 at 8:13 PM
  This message has been viewed 125 times.
In Reply To Thermostat Housing posted by ZXRider(SoCal) on January 13, 2010 at 06:54 PM
Message :Is there anyway to install it with both heads still on the block or
:do one of the heads have to come off?
:I was able to remove it without removing the heads but now I am
:doubting if I can install it, or at least install it without the RTV
:being smeared all over the place.
Correct me if I'm wrong but, isn't the thermostat housing located on the front of the engine? All I had to do to remove it was remove the radiator, shroud, and fan to access the nuts/bolts that hold it on. At no point did I mess with the heads. As far as the RTV, if you use the right amount ( just enough to cover the housing) you shouldn't smear it all over the place.
