TwinTurbo.NET: Nissan 300ZX forum - Strange I have had no issues with the Goodyear J30R9 >>
ZUL8TR
on January 13, 2010 at 7:40 AM
I think it has been measured out to just under 7 feet.
posted by jmt-z
on January 12, 2010 at 05:20 PM
and the OEM clamps.
ZUL8TR in Orlando,FL
Replacing fuel line in the engine bay! How much do i need?
JonnyZ(SoCal)
16:20:50 01/11/10
All the fuel lines in the bay are the same size --
jzack
18:08:30 01/11/10
Thanks, thats the kinda info i was looking for! (n/m)
JonnyZ(SoCal)
18:45:45 01/11/10
Re: All the fuel lines in the bay are the same size --
CmyZ
06:09:17 01/12/10
A lot have used Goodyear FI hose a a much lower >>>
ZUL8TR
09:02:06 01/12/10
Ya, but isnt the goodyear slightly bigger than 8mm?
JonnyZ(SoCal)
13:04:21 01/12/10
The 5/16" (= 7.94mm) ID is a great fit, worked for me. (n/m)
ZUL8TR
16:08:31 01/12/10
Can you use oem clamps with GY? (n/m)
JonnyZ(SoCal)
16:47:19 01/12/10
Yes (n/m)
Fast300
18:21:01 01/12/10
x 2 (n/m)
ZUL8TR
07:07:33 01/13/10
FWIW: The 5/16 fuel line has a thicker outside diameter than
jzack
22:30:36 01/12/10
I just measured the OEM and the Goodyear FI hose|>>>
ZUL8TR
07:35:33 01/13/10
That's a good point with both hoses being new....
jzack
17:22:22 01/15/10
jmt-z
17:20:09 01/12/10
Everything i have read says 8mm, where did you see 7mm? (n/m)
JonnyZ(SoCal)
23:08:28 01/12/10
8mm is the correct ID (n/m)
ZUL8TR
07:36:05 01/13/10
Strange I have had no issues with the Goodyear J30R9 >> -
ZUL8TR
07:40:40 01/13/10
I had the same problem...
flashstar
10:13:49 01/13/10
if you put your hoses on in the summer, you going to have to
fanta-z
17:51:11 01/13/10
