TwinTurbo.NET: Nissan 300ZX forum - If the lifter tick is mild there will not be any significant
Subject If the lifter tick is mild there will not be any significant
Posted by ZUL8TR on January 12, 2010 at 10:54 AM
  This message has been viewed 112 times.
In Reply To Lifter Tick posted by Steve300Z on January 11, 2010 at 01:40 PM
Message damage.
What brand and weight oil have you been using?
There are several cleaners on the market. Marvel MO, Shaler Riselone, etc. All are OK for limited use. But preferred to get engine clean and use straight oil no additives.
Marvel MO is a detergent cleaner and adding a quart will not damage anything and might just work. However if you add it be sure to remove a quart before you add or the engine pan will be overfilled and that is not good.
If you add the Marvel run it for a couple hundred miles and then dump it and change the oil to a brand name 10w 30.
I have a 92 NA w 86k (bought in 92) and have never had lifter tick engine is quiet as a mouse. Been using Castrol 10w 30 dino most of the time, several years with Mobil 1 synthetic 10w 30, and a few fills with Valvoline dine. Been doing 4k to 5k or each 4 to 5 months if mileage not met oil and filter dumps. OEM, WiX or Purolater filters.
ZUL8TR in Orlando,FL
