TwinTurbo.NET: Nissan 300ZX forum - Re: All the fuel lines in the bay are the same size --
Subject Re: All the fuel lines in the bay are the same size --
Posted by CmyZ on January 12, 2010 at 6:09 AM
  This message has been viewed 199 times.
In Reply To All the fuel lines in the bay are the same size -- posted by jzack on January 11, 2010 at 06:08 PM
Message Why would you replace a hard line for a rubber hose???
Unless you were using 300 Degrees fuel rails, I don't see the logic. The steel line is better.. You will need approximately 4 feet or 48" from the fuel filter / return pipes. Use OEM Nissan fuel hose.
