TwinTurbo.NET: Nissan 300ZX forum - it depends on the car, on the Z it builds boost
Subject it depends on the car, on the Z it builds boost
Posted by The Devils Z on January 10, 2010 at 8:36 AM
  This message has been viewed 90 times.
In Reply To Re: Re: Water Injection AGAIN !!! help tuning !!! posted by paintballkustoms on January 10, 2010 at 02:46 AM
Message so fast and the boost range is pretty small where the spray would be on ( 8psi - 16psi as an example ) and on top of that most z guys are not running different timing maps ~ tuning is not necessary. You need a top notch expensive water injection system to run a tune just for water injection which allows for a fail safe when the injection is not on.
The safest thing to do and cheapest is to run about 3psi extra boost with the spray. That will give you about 30 rwhp extra.
=============Sig begins here================
The Devils Z.com
The Devils Z Pic
666 rwhp dyno
The Demon Z pic (in progress)
View Me! Disclaimer : Not Safe For Work !
