TwinTurbo.NET: Nissan 300ZX forum - Re: Water Injection AGAIN !!! help tuning !!!
Subject Re: Water Injection AGAIN !!! help tuning !!!
Posted by txq45 on January 09, 2010 at 10:51 AM
  This message has been viewed 107 times.
In Reply To Water Injection AGAIN !!! help tuning !!! posted by paintballkustoms on January 09, 2010 at 02:46 AM
Message if your not running alot of Alcohol you don't need another tune. Just need to tweak your injection system for the water/alcohol.. Example ,, what boost level to come on and what boost level to turn off.. If you have the controller you can start with a low volume.. I've used coolingmist for over 2 years now and have had no problem with it on the lower volume settings along with using a 30/70 alcohol/water mix/.
