TwinTurbo.NET: Nissan 300ZX forum - Russell thank you for the sound advice.
Subject Russell thank you for the sound advice.
Posted by Burg300zx91 on January 07, 2010 at 9:42 PM
  This message has been viewed 97 times.
In Reply To Sounds like a crack in the block, head, or even a turbo. posted by Russell@Z1 on January 07, 2010 at 09:33 PM
Message The motor was reassembled per the factory service manual.
The studs were seated with lock tight in the block (2 shorties
where they belong) and then torqued in the order and steps
listed in the FSM.
I took my LED light and examined every square inch of the
cylinder walls with no visible signs of cracks, but as you said,
these aren't always visible.
The next thing i'm going to try is pressurizing the coolant
sytem, pulling the plugs out and cranking it over to see if the
cylinders are filling up with water...
If there is nothing being revealed there, Would it be possible
for coolant to be introduced into the oil system through a
faulty turbo charger?
