TwinTurbo.NET: Nissan 300ZX forum - Sounds like a crack in the block, head, or even a turbo.
Subject Sounds like a crack in the block, head, or even a turbo.
Posted by Russell@Z1 on January 07, 2010 at 9:33 PM
  This message has been viewed 118 times.
In Reply To I need your advise (put your thinking cap on) posted by Burg300zx91 on January 07, 2010 at 08:20 PM
Message Rare but we have seen it before and it can cause oil to be rapidly introduced into the coolant system. If the problem is due to the gasket being breached it is some sort of user error. Highly unlikely its a problem caused because of the gasket itself. Did you put the two short head studs in the correct locations? Of course I have no way of knowing your skill level, but if you did everything even remotely right and are having the same problem twice I would lean towards a crack in your block being the problem. From my experience you probably won't be able to find it either without a pressure test which we've made some special fixtures to perform. They can be internal and not visible even after maganfluxing..
Russell Floyd
Z1 Motorsports
www.300zx.com
1990+ Nissan Z specialists
Used Parts, New parts, Service/Repair and Performance
Z1 Motorsports Exclusive Parts Line
2877 Carrollton Villa Rica Hwy
Carrollton, Ga 30116
770-838-7777
770-832-9253 (fax)
