TwinTurbo.NET: Nissan 300ZX forum - czp? do you mean 3zc? do another compression test
ali300zx
on January 07, 2010 at 8:27 PM
I need your advise (put your thinking cap on)
posted by Burg300zx91
on January 07, 2010 at 08:20 PM
then leakdown test. i think you should go with OEM headgaskets next time instead of the cometic. if the surfaces aren't perfectly machined for the mls gaskets, it won't seal
Burg300zx91
20:20:13 01/07/10
czp? do you mean 3zc? do another compression test -
ali300zx
20:27:24 01/07/10
:sorry used to typing CZP. I meant 3ZC.
Burg300zx91
20:35:29 01/07/10
did you not inspect that turbo while you had it out? (n/m)
ZLover4Life
20:31:23 01/07/10
I tested the shafts for play but didn't know
Burg300zx91
20:37:38 01/07/10
did you send in the block to have it checked or just did a
alpha_omega16
02:33:14 01/08/10
Re: did you send in the block to have it checked or just did a
Burg300zx91
13:41:10 01/08/10
Re: I need your advise (put your thinking cap on)
txq45
20:58:21 01/07/10
1: 150 3: 130 5: 142 (n/m)
Burg300zx91
21:11:10 01/07/10
What was the pressure of the other bank? (n/m)
alpha_omega16
02:31:10 01/08/10
Re: What was the pressure of the other bank?
Burg300zx91
13:39:33 01/08/10
Sounds like a crack in the block, head, or even a turbo.
Russell@Z1
21:33:31 01/07/10
Russell thank you for the sound advice.
Burg300zx91
21:42:54 01/07/10
Pressurizing the coolant system and seeing if you get any
Russell@Z1
11:36:02 01/08/10
Re: Pressurizing the coolant system and seeing if you get any
txq45
13:34:11 01/08/10
Russell... One thing regarding your comment
Burg300zx91
21:56:45 01/09/10
Finding a machine shop that can properly pressure test
Russell@Z1
09:36:56 01/10/10
