TwinTurbo.NET: Nissan 300ZX forum - The loose belts should not be the cause of this issue...
Subject The loose belts should not be the cause of this issue...
Posted by jzack on January 07, 2010 at 6:38 PM
  This message has been viewed 95 times.
In Reply To Re: Does it turn over? battery voltage ok? posted by fairladysarah on January 06, 2010 at 11:02 PM
Message the sound you heard while driving/reving over 4K rpms probably was caused by a loose belt squeeling...
Check both the PTU and CAS plugs/wiring harnesses -- they are in the same area where you were working and issues there would keep the car from starting....
