TwinTurbo.NET: Nissan 300ZX forum - Hey boys, i need your help real quick!
Subject Hey boys, i need your help real quick!
Posted by fairladysarah on January 06, 2010 at 10:25 PM
  This message has been viewed 187 times.
Message ok, I've tried to do some research on this site, but honestly I didn't know where to start off...
Here are the jobs that I recently performed on my car:
removed started, cleaned and installed
installed new OEM alternator
installed UR pulleys (power steering, crank, water pump)
along with the pulleys, new belts (gates)
installed new OEM clutch fan
after I installed everything, I went for a test drive, and when i was warming up the car, it was fine idling for about 15 minutes. But then when i started driving it, as soon as the RPM climbed over around 3-4k, the car made a strange whining noise so I got scared and shut off the car, and now the car will not start.
I was wondering if the engine does not start if the belt is loose.. I thought I tightened the belts to spec but after this incident I realized that my belts were loose. Could this be the problem?
