TwinTurbo.NET: Nissan 300ZX forum - Using TP to limit boost....
Subject Using TP to limit boost....
Posted by zx299 on January 05, 2010 at 6:56 AM
  This message has been viewed 116 times.
In Reply To Re: Boost can be limited by shortening TP..... posted by Vanos on January 05, 2010 at 02:49 AM
Message Set the last TP column of your fuel map at less than the max TP your motor achieves. The motor is now limited to the TP value of the last column.
Imagine your fuel map has 96 as the last TP column and your engine just reaches that column at WOT. If you rescale the map making the 64 column your last column you have effectively "governed" your motor by limiting the fuel supply.
If you look at a fuel map you'll notice that at a given rpm the fuel supply increases as you move across the TP columns. If you stop the TP increase you stop the fuel increase, no extra fuel equals no extra boost.
"If you own a 300zx, you don't have time for a hobby"
"If you own more than one 300zx, you don't have time for a life"
