TwinTurbo.NET: Nissan 300ZX forum - Get under the car and verify the slave piston is pushing the
Subject Get under the car and verify the slave piston is pushing the
Posted by Gordo 93TT Daytona on January 04, 2010 at 9:23 PM
  This message has been viewed 89 times.
In Reply To Clutch Issue/Stuck in gear on startup posted by wrxfl on January 02, 2010 at 11:37 PM
Message throw-out fork in and out. If it is not actuating properly, remove the rubber grommet from the access hole and insure the pivot bolt has not broken off. The clutch is a very straightforward mechanical piece and you should be able to identify the cause of your problem easily.
_________________________________________________
