TwinTurbo.NET: Nissan 300ZX forum - It would be easier to pull the plenum, IMO...
Subject It would be easier to pull the plenum, IMO...
Posted by BradX (UF) on January 04, 2010 at 3:22 PM
  This message has been viewed 165 times.
In Reply To EGR stuck, huge vacuum leak, need your opinions posted by surfer31337 on January 04, 2010 at 02:13 PM
Message Even if the tranny was out of the way, you still have to deal with all the tubes connected to the EGR valve. Once the plenum is removed, you can get to the two bolts that hold the EGR to the back of the lower plenum. However, you can still bypass the EGR without necessarily physically removing it. Get the kit, block the underside ports on the plenum and you should be fine.
-Brad
'92 Z32 2+2 SOLD
'00 VG33 Banana Boat
'91 MX83 1JZ
________________________
1. It's just a car.
2. Cars were meant to be driven.
"I believe anyone should be allowed to enjoy his or her Z however s(he) sees fit." - robo (sebring1970) on March 04, 2009 at 1:20 PM
"You brad are just a car owner who only cares about yourself and not a true enthusiast..." - Spongerider :) on March 07, 2008 at 6:01 PM
"Unless it has a vagina, its just a car." - Kenny on January 18, 2008 at 9:57 AM
"Why upgrade a car if you don't take it out and beat up on it every now and then?" - fourZero on October 11, 2007 at 1:37 PM
"...when i've been in florida, people drive crazy, dangerous, and fast." - ARA300ZX on January 10, 2007 at 12:06 PM
"They turn their head because the 2+2 is sooo long." - ZJeweler(ssm300z) on July 13, 2006 at 4:43 PM
"The Z was meant for the track, not the dragstrip." - Moxie on May 01, 2006 at 3:03 PM
