TwinTurbo.NET: Nissan 300ZX forum - Ash is correct....
Subject Ash is correct....
Posted by zx299 on January 03, 2010 at 4:29 PM
  This message has been viewed 94 times.
In Reply To Tuning/mapping question posted by Vanos on January 03, 2010 at 06:03 AM
Message It's simple really. If your engine TP exceeds the last column of your maps, the ecu is going to use the last column no matter what TP your engine is reaching. This feature can be used as a safety guard to limit "overboosting". That is why Ash told you to set your maps slightly under your engines peak TP.
If you have datalogging capabilities your logs will tell you what your max engine TP is and you can set your maps accordingly.
"If you own a 300zx, you don't have time for a hobby"
"If you own more than one 300zx, you don't have time for a life"
