TwinTurbo.NET: Nissan 300ZX forum - Clutch Issue/Stuck in gear on startup
Subject Clutch Issue/Stuck in gear on startup
Posted by wrxfl on January 02, 2010 at 11:37 PM
  This message has been viewed 251 times.
Message Hey all,
Well I recently installed a new dxd clutch/flywheel combo about 4 months ago and all has been fine up until today. Over the past week I notice a loud (almost belt like) intermittent squeak when engaging 1st gear and reverse from a stop. The noise went away however when the gear was fully engaged and while driving, it only occured when engaging from a stop. Anyhow, today while driving the car got stuck in gear. When I tried starting the car in any gear with the clutch depressed the car tried to lurch forward and when I started the car in neutral and tried to shift it into gear it wont go into any gear. However, when the car is off I can shift into any gear with no problem whatsoever. Also worth mentioning is that the clutch pedal feels firm and normal, like it did before the problem began. Thanks for your help and any light you can shed on the issue is greatly appreciated!
Matt
