TwinTurbo.NET: Nissan 300ZX forum - I recommend the tie rod puller because it will not >>>
Subject I recommend the tie rod puller because it will not >>>
Posted by ZUL8TR on December 30, 2009 at 9:06 AM
  This message has been viewed 129 times.
In Reply To outer tie rods posted by KasbeKZ on December 29, 2009 at 06:03 PM
Message damage the rubber boot. The fork will most likely damage the boot and result in having to replace the ball joint and boot assembly. Auto zone will let you buy the puller and then return it for a refund. I have done that several times. You just need to get the right puller they make several.
ZUL8TR in Orlando,FL
