TwinTurbo.NET: Nissan 300ZX forum - EGR delete kit is about $30. The stock oil pump should be
Subject EGR delete kit is about $30. The stock oil pump should be
Posted by zellamay on December 28, 2009 at 8:02 PM
  This message has been viewed 103 times.
In Reply To Re: Plus, you can inspect the engine and test the heads. posted by WillsCustoms on December 28, 2009 at 03:48 PM
Message fine if it's in good shape. 24 psi is a lot. What turbos will you use? Have you considered MSP exhaust manifolds while you've got it apart? Also, if you are replacing downpipes, go with 3" expansion dp's. Last thoughts while you have it apart: engine wiring harness and EBC ...
