TwinTurbo.NET: Nissan 300ZX forum - Remove the rear water tubing/hoses to remove lower plenum?
Subject Remove the rear water tubing/hoses to remove lower plenum?
Posted by oherr on December 27, 2009 at 5:15 PM
Message I see two nuts at the very back of the lower plenum(intake manifold), but access to them from above is blocked by water tubing and hoses. Do I need to remove these last two nuts in the very back? If so, is there another way, or do I have to remove the rear water tubing and hoses?
Thank you for your help. I thought the lower plenum would be easier, but it's turning out to be quite a challenge with fatigue setting in. Thanks!
