There are several holes around the rotating shaft , allowing you to tilt the engine from side to side while you work on it \ NOTE : THE ENGINE IS VERY HEAVY AND WILL TRY TO SPIN IF YOU ROTATE IT . Keep a good grip on it as you rotate it and you'lll be fine.
