TwinTurbo.NET: Nissan 300ZX forum - Re: How do you set the crank balancer pulley to "0"?
Subject Re: How do you set the crank balancer pulley to "0"?
Posted by xteam300tt on November 09, 2009 at 10:04 PM
  This message has been viewed 193 times.
In Reply To How do you set the crank balancer pulley to "0"? posted by Zarcasm(Hfd, CT) on November 09, 2009 at 09:26 PM
Message turn the crank using a 27mm socket until the mark on the crank pulley lines up to the "0" on the measure indicator on the lower timing cover . dont linr them up while looking straight down from the middle of the engine , you need to tilt your head to the left 15 to 20 degrees to get an accurate alignment of the marks and not be fooled by divergency
