TwinTurbo.NET: Nissan 300ZX forum - Would assume you've verified the engine timing
jzack
on November 08, 2009 at 10:22 PM
Post Timing Belt Change-Loss of Power?
posted by Nikknakz
on November 08, 2009 at 06:55 PM
with timing light as well?
Nikknakz
18:55:25 11/08/09
Pull back the timing covers and doublecheck everything
twinturbineZ
19:23:45 11/08/09
Re: Post Timing Belt Change-Loss of Power?
WazTTed
20:45:15 11/08/09
Would assume you've verified the engine timing -
jzack
22:22:27 11/08/09
ZTurboFan
10:15:04 11/09/09
Re: Re: Post Timing Belt Change-Loss of Power?
Nikknakz
19:39:55 11/09/09
You can get an idea if the belt is off
canyoncarver
20:13:54 11/09/09
How do you set the crank balancer pulley to "0"?
Zarcasm(Hfd, CT)
21:26:08 11/09/09
Re: How do you set the crank balancer pulley to "0"?
xteam300tt
22:04:10 11/09/09
Re: Re: How do you set the crank balancer pulley to "0"?
ZTurboFan
00:28:42 11/10/09
A properly installed timing belt can appear to be off
canyoncarver
06:51:56 11/10/09
Re: A properly installed timing belt can appear to be off
ZTurboFan
10:42:11 11/10/09
Re: A properly installed timing belt can appear to be off (n/m)
Nikknakz
22:22:26 11/10/09
Nikknakz
22:27:20 11/10/09
Yes, being off 1 tooth can affect performance.
canyoncarver
06:15:53 11/11/09
Thanks folks (n/m)
Zarcasm(Hfd, CT)
22:26:02 11/10/09
sounds like Zarcasm (n/m)
canyoncarver
06:43:23 11/10/09
